K&B .67 inboard parts
Postby Brianl1620 » Wed Dec 29, 2010 9:30 am
I have a K&B .67 inboard engine, serial number 05083. It has the one piece case , the cast backplate and the carb. with the venturi. I was wondering if I could put the newer machined backplate and the newer carb. with the mixture disk and remote needle valve on my engine. If I can where can I get these parts? Also do you know when my engine was made? thanks
Brianl1620
Postby Brianl1620 » Wed Dec 29, 2010 9:57 am
if can do this what part numbers do I need?
Brianl1620
if I can do this what part numbers do I need?
Brianl1620
Postby MECOA » Thu Dec 30, 2010 9:26 pm
You must modify the crankcase by cutting a passage for the inlet
look here at the 3.5 case and you can see
http://www.mecoa.com/parts/10/10-89/10-89.htm
you would need part number 21-6791
put it in here
Users browsing this forum: No registered users and 198 guests
