by mallen » Tue Oct 05, 2010 4:43 am
Is it possible to run the K&B 61 ABC piston and liner in the ringed 61 crankcase with bolt on head? If so, are there any other parts I would have to swap out?
Mark
mallen
by MECOA » Fri Oct 08, 2010 11:40 am
The ABC cylinder has porting that requires 2 small channels to be milled in the crankcase.
So you would have to mill the channels in the case and change the head as these is no baffle on the piston.
by mallen » Fri Oct 08, 2010 5:59 pm
Thanks for the info!
Mark
mallen
Users browsing this forum: No registered users and 112 guests
