KB 7.5 Outboard Engine Bearing
Postby rdc500 » Sun Sep 19, 2010 5:46 pm
I am looking for a bearing that on inspection is stamped Japan-Gulf, B-15R8
The ID is .589, OD 1.124 Width .247 I need this to finish the Engine. Thanks for all your help. :)
rdc500
Postby chiefss » Sun Sep 19, 2010 9:02 pm
That's a standard 15x28mm bearing that's used in just about every 30 to 46 size engine out there. Try mecoa.com in the accessory section.
Postby rdc500 » Sun Sep 19, 2010 9:16 pm
Thanks for the fast reply, I will order one today. Thanks again
rdc500
Users browsing this forum: Google [Bot] and 88 guests
