veco .61 with pump
veco .61 with pump
Postby frank » Fri Sep 17, 2010 1:10 pm
Hello. I have an old Veco .61 R/C with a pump on the back, attached directly to the engine. All the engine says is: VECO 61. It at one time had an exhaust baffle, but it is gone. There is no muffler. I thought I would post a few questions before running it.
The compression seems low. Is this normal for this engine? Should I try to get the pump working, or is it too old? Do I need to have some kind of back pressure to get the pump to work?It hasn't been run in over 25 years. I have an 11/6 prop. Also a 12/6. Does it matter? Finally, what fuel does it prefer?
Thank you for your time.
Regards,
Frank in Montana
frank
Postby chiefss » Fri Sep 17, 2010 1:51 pm
It's the forerunner of the K&B 61. Exact same engine. There is nothing to do with the pump. Either it works or it doesn't. The diaphragm may be shot after sitting all these years. The only way to find out is to run it.
The compression may be low because these engines used a dykes ring. Flip it backwards and see if the compression doesn't improve.
11x7 or 12x6 prop is fine.
Postby frank » Fri Sep 17, 2010 2:04 pm
Thank you. Guess I'll fire it up and see what happens.....to be continued
frank
Postby frank » Fri Sep 17, 2010 4:23 pm
It ran, and the pump works! I flooded it badly, but got it started by hand. The Perry carb seemed to be leaking, so I took it off. It was missing a screw under where the fuel line attaches to the carb. I don't know what it is for, so I just serewed it in all the way. I had a spare carb, so took a screw off it and that seemed to solve the problem. A little fuel does seep out of the front of the crankcase, but I assume that is normal. I flooded it again, so I closed the needle valve and flipped it until it ran out the fuel, then opened the nv about two turns, and used an elect. starter. Got it running easily two more times The carb may need a little tweeking, but other than that, it ran quite strong. Maybe I'll build a Dirty Birdy for it!
One more question: What would be the right muffler for this engine?
Thank you so much....
Frank in Montana.
frank
Postby chiefss » Fri Sep 17, 2010 6:35 pm
K&B made a muffler for this engine. Check with Mecoa.
Veco 61 muffler
Postby frank » Sat Sep 18, 2010 8:25 pm
MECOA might have one, but it is $40.00 plus shipping. Think I'll look around...
frank
Postby Ilikebipes » Sun Nov 21, 2010 8:01 pm
Can a Veco pump be successfully mounted to a K&B body and used successfully?
Ilikebipes
Postby chiefss » Sun Nov 21, 2010 10:08 pm
They are the same engine. K&B bought out Veco and Mecoa bought K&B.
Postby MECOA » Tue Nov 23, 2010 1:51 pm
Most of the back cover perry pumps go bad after so many years as the rubber diaphragm hardens up.
Postby chiefss » Wed Nov 24, 2010 2:48 pm
So true. The trick is to keep the intake and output connected with a piece of rubber tubing.
Users browsing this forum: No registered users and 56 guests
