3.5 outboard K&b motor Question
Postby hotpup » Sun Aug 22, 2010 1:52 pm
Where can I find a diagram of the flex shaft, I am needing to replace mine, I have the part, I just dont know how to replace it
hotpup
Postby SteveM » Mon Aug 23, 2010 4:03 am
Remove the four bolts that secure the lower unit to the PTO and separate the two parts. You will see the flex cable in the lower unit and you just pull it out. The cable has square ends that engage the PTO and the lower prop hub assembly. Once removed, add a little grease to the new cable and just slide it in being sure to engage the prop hub. Re-attach the lower unit to the power head.
Users browsing this forum: No registered users and 152 guests
