11cc outboard
Dumas Hot Shot Sprint (Tunnel)
35% Sig Fuel
McCoy 8 plug
14 oz tank with 1 oz hopper
Low speed needle at factory
High speed 3 1/2 turns out
Had issues with enough pressure to keep fuel flowing. After priming, it would start, run at a extreme RPM (seemed like full open) @ 1/8 to 1/4 open throttle and die. Removed the hopper and tried again. Got it running, still seemed to idle at a very high RPM for 1/8 to 1/4 open throttle. About 10 laps... 1/2 tank of fuel it dies. Open needle 1/2 turn. Got it going again by priming... and it would not stay running consistantly. Tore carb down tonight and it's clean.... Read the manual over and over... I need help!!
1> Does the outboard make enough pressure for a hopper tank
2> Any thoughts on the extremely high idle?
3> Should I need to re-prime at every re-start
Thanks for the help!!!
Aaron W.[/b]
