by bigphil » Tue Aug 04, 2009 7:29 pm
It's not clear to me from the parts listing if I can convert a remote needle carb to use the old style disk and carb mounted needle. If I change the disk and get the needle mounting components with this work with the new remote needle carb?
Phil
bigphil
by MECOA » Wed Aug 05, 2009 7:26 am
Yes but the eccentric screw usually won't have a hole to thread into. If you don't have the eccentric screw the disk can turn when adjusting the high speed needle.
Users browsing this forum: No registered users and 30 guests
