K&B Outboard Prop Shaft Size?
Postby fishinghole » Mon Jun 22, 2009 7:19 pm
Could someone tell me the correct mini open end wrench sizes that fit both the 3.5 & 7.5 outboard prop shaft hubs to remove? Thanks!
John
fishinghole
Postby USMC » Mon Jun 22, 2009 9:23 pm
for the 3.5 you will need a flat or thin 5/16 open end wrench, this is for the prop shaft that screws into the lower half. facing the prop from the rear turn clockwise to remove.
the prop nut takes a 1/4 inch socket.
I dont have a 7.5 engine.
Good Luck,
USMC & Viking...! & Little Jack...! :)
USMC
Postby USMC » Tue Jun 23, 2009 1:02 pm
do not try to unscrew the prop shaft assembly all the way, just make it back off the lower end a bit. this will make it easy to separate the halves apart.
USMC
Postby MECOA » Tue Jun 23, 2009 3:16 pm
7.5 takes a 7/16"
LEFT HAND THREAD FOR BOTH
DO NOT OVER TIGHTEN
Postby fishinghole » Tue Jun 23, 2009 6:28 pm
Do any of you have a sourse for thin open end wrenches? Can't find them anywhere around here. Thanks!
John
fishinghole
Postby USMC » Tue Jun 23, 2009 9:06 pm
check with Sears or a Auto parts Store,
the ones that I am using are the cheap Taiwan ones,
that come in a small plastic vinyl case.
if you cant find, I do have a 7/16 and,
a 21/64 (just a bit larger than the 15/16 but not by much, and should work for you.)
Take Care,
USMC
Users browsing this forum: No registered users and 83 guests
