by rjustin » Tue Jun 09, 2009 8:40 am
What are the 4 holes for on the bottom of the lower end, 2 on each side of the unit where the prop shaft is by the propeller? should you be able to see the flex shaft thru these holes. thanks
rjustin
by MECOA » Tue Jun 09, 2009 8:20 pm
Those allow water in to cool the shaft. You should not see the flex shaft thru those holes
by rjustin » Tue Jun 09, 2009 8:28 pm
Thanks. the holes closer to the propeller are ok but the others I can clearly see the flex shaft. Is there some sort of seal that I need to replace to correct this? Thanks again
rjustin
by MECOA » Fri Jun 12, 2009 4:30 pm
I stand corrected, if you do look close you can see the flex shaft in the forward holes. No seal. You must keep the flex shaft lubed with water proof grease.
Users browsing this forum: Majestic-12 [Bot] and 71 guests
