torquing head bolts on .40 marine engine
Postby ericmcrory » Sun Apr 19, 2009 10:22 pm
Is there a torque pattern to tighten the head bolts when reasembling the head? (K&B .40 marine inboard engine). What about amount of torque?
ericmcrory
Postby MECOA » Mon Apr 20, 2009 6:59 pm
Insert screws into head and tighten until they just touch the head. Then tighten them in the cross pattern. Tighten the screws only slightly, repeating the sequence a number of times until the screws are tight to about 5.2 inch lbs.
Torque wrench
Postby dieselfun » Tue Sep 28, 2010 7:37 am
[quote="MECOA"]Insert screws into head and tighten until they just touch the head. Then tighten them in the cross pattern. Tighten the screws only slightly, repeating the sequence a number of times until the screws are tight to about 5.2 inch lbs.[/quote]
Can you recommend a not too expensive torque wrench for hobby usage but adequate for small engines?
Regards
dieselfun
Postby SteveM » Tue Sep 28, 2010 8:06 am
I've never used a torque wrench on my hobby motors and have never had an issue. You just need to use reasonable force.
Torque
Postby dieselfun » Tue Sep 28, 2010 8:09 am
[quote="SteveM"]I've never used a torque wrench on my hobby motors and have never had an issue. You just need to use reasonable force.[/quote]
Thanks for your advise.
REgards
dieselfun
Postby dedaddy007 » Tue Sep 28, 2010 8:11 am
Garrett Wade sells one that I have used for a long time. You can see it here: http://www.garrettwade.com/adjustable-t ... /08G01.03/
dedaddy007
Users browsing this forum: No registered users and 73 guests
