.65 Sportster Props
.65 Sportster Props
Postby RC Pilot » Tue Mar 24, 2009 3:23 pm
I have a twin with 2, .65 sportsters on 2 bladed props & it's too fast and yes, I know how to use throttle. How big a 3-blade can I use? Motors are mounted with the heads outboard and mufflers at the bottom. I can adjust them close enough without electronic help such as a synch. I use a tach, however. What would you suggest for a 3 blade prop? :?:
RC Pilot
Postby MECOA » Thu Mar 26, 2009 8:59 am
11x6 or 11x5
Postby RC Pilot » Thu Apr 09, 2009 1:56 pm
I am already running 12X6 3-blade props and it still flies like it's tail is on fire. Should I try a 12X8 if I can find one or is a 13" available?
RC Pilot
Postby MECOA » Fri Apr 10, 2009 5:20 am
I said...
11x6 or 11x5
You said you want it to go slower.
Users browsing this forum: No registered users and 138 guests
