by stumblebum » Wed Jan 14, 2009 7:25 pm
I am in the process of refurbing a Sig Kadet Mark II. I have a K & B 40, model 4011 that was purchased somewhere between 1978 and 1981.
It came with an Irvine carburetor even thou the box stated Perry. My main problem with the Irvine is there is no retainer/holder beside the needle valve to hold it in place. I install a new O ring on the needle and it works for a while then vibration either turns the needle too lean or too rich.
Since the part sheet shows this carburetor is not availible, what carburetor can I use as a replacement? This is mounted in the Kadet with the supplied cowl and I don't know if I can adapt it for remote needle or not.
Thanks ahead of time for any suggestions.
Stumblebum
Hopefully this post is in the correct place.
stumblebum
by MECOA » Mon Jan 19, 2009 9:17 pm
The only carb we have available is the latest K&B carb withthe remote needle.
Item 80-5902
by deadstick60 » Thu Jun 18, 2009 11:48 am
stumblebum, would you like to sell this carburetor? If so email me at
noell4@msn.com, as my carb body is cracked from a crash.
deadstick60
Users browsing this forum: Google [Bot] and 119 guests
