K&B 6.5cc SRII C/L racing engine- piston & sleeve.
Postby mart101 » Wed Jan 14, 2009 4:22 am
Hi,
Does mecoa stock any spare parts for this engine- piston& sleeve, bearings etc.?
Martin
mart101
Postby MECOA » Mon Jan 19, 2009 9:14 pm
Yes I have the piston & liner
call 800-359-6972
6.5cc SRII Parts and technical question
Postby mart101 » Tue Sep 08, 2009 5:10 am
I now have a number of parts for this engine but need some advice as there seems be a slight difference in the piston and liner design.
I have got a rear induction 6.5cc with drum valve, and the con rod is
circular rather than flat like the other SRII model I have, it also appears to be longer and the wrist pin is set higher in the piston to offset this.
The exhaust port is also split into 2 halves, with a thin liner bar running up the center, my other SR II engine does not have this.
Is this a later model for ducted fan use ? Do you carry spare piston & liner
and con rod for this type ?
Can you tell me what the port timing is on these models so I can calculate pipe length.
Martin
mart101
Postby MECOA » Tue Sep 08, 2009 7:02 am
Parts changed over the 25 years of production. All should interchange,
Users browsing this forum: No registered users and 109 guests
