Sportster .20 Piston hits Head
Postby rainedave » Fri Nov 28, 2008 4:42 pm
Hi, I have a NIB Sportster .20 and the piston hits the head. There is no place to add a shim under the head, so I installed a gasket between the case and the cylinder. This fixed the problem, but doesn't seem like the best fix since it alters the timing.
Was this a common problem with these engines? What is the best way to fix it?
David
rainedave
Postby MECOA » Tue Dec 02, 2008 8:55 am
Where did you get this? It probably has a .28 crankcase and .20 piston cylinder. The .28 crankcase was shorter. I have brass shims for this.
Postby rainedave » Tue Dec 02, 2008 5:12 pm
Thanks. The mounting lug has A3920 stamped on it. This is also written in magic marker on the box. The address on the box is Lake Havasu City, AZ, so I assume that's where it was manufactured.
How can I order the shims?
David
rainedave
Postby MECOA » Thu Dec 04, 2008 11:45 am
call 626-359-0016
