Piston direction on K&B 7.5 Inboard
Postby jackl » Sun Oct 26, 2008 7:48 am
Does the wrist pin go into the piston from the exhaust side exposing it when you look into the exhaust port?
regards
jack
jackl
Postby MECOA » Sun Oct 26, 2008 8:04 pm
sually the wrist pin with a pad will have the pad opposite the exhaust. The pad must always run against a portion of the cylinder. I can not pass over an open port. If it does it has the possibility of popping into the open port and causing damage.
http://www.mecoa.com/faq/whichway/piston/piston.htm
Postby jackl » Mon Oct 27, 2008 5:39 am
So, does that mean the exploded view for the 7.5 marine engine is incorrect?
Regards,
Jack
jackl
Postby MECOA » Sat Nov 01, 2008 3:30 pm
If the exhasut port has a web it is fine. if not it is not.
Postby jackl » Sat Nov 01, 2008 4:16 pm
got it.
thanks for all the info.....
jack
jackl
