what model is my k&b 7.5 outboard?
Postby cricket12835 » Fri May 09, 2008 3:55 pm
I need to order crank bearings. Either side of the crank case the O.D is the same.
cricket12835
Postby MECOA » Sat May 10, 2008 8:22 pm
This is the early case so it uses the 15 mm rear bearing.
http://www.mecoa.com/kb/87/870102-exp.pdf
