by Charlottedarter » Sun Nov 25, 2007 6:19 am
Can someone help me with instructions for removing the crankshaft? bearings and flywheel?
Thank you!
Charlottedarter
by MECOA » Thu Nov 29, 2007 6:52 pm
Crankshaft must be pressed out the rear of the engine after the piston/cylinder and con rod have been removed. The flywheel or prop driver is just pressed onto a teppered collet and can be pulled off the front with a puller.
