older K&b .45
older K&b .45
Postby Hipshot » Fri Nov 16, 2007 5:46 pm
I pulled the leaking head and found an aluminum flat gasket ring warped and out of shape. I ordered an\ new head gasket and got rubber o rings... is this the proper replacement? thanks for your help
Hipshot
update
Postby Hipshot » Sun Nov 18, 2007 7:57 pm
I put in the o rings sent ans as suspected they completely melted. this CANNOT be the right part! Although the parts list says its correct. please help
Hipshot
Postby MECOA » Thu Nov 29, 2007 6:44 pm
Actually if you read the notation in the parts dept and on the parts list the o-ring was only used on the very early models. It was later replaced by the metal shim.
http://www.mecoa.com/kb/59/59-parts.htm
and
http://www.mecoa.com/kb/56/sportster.pdf
Postby Hipshot » Thu Nov 29, 2007 8:44 pm
yeah I saw that later... i reordered the "right" part! :roll:
Hipshot
