by winzracing » Sat Sep 01, 2007 11:27 pm
Hi...Does anyone know how to change the timing on outboards...I believe when fitting a tuned pipe the engines timing has to be changed...Apparently running a stock engine on a tuned pipe dosent do much if the timing hasnt been changed???? Thanx for any info anyone has
winzracing
by SteveM » Sun Sep 02, 2007 7:25 am
There is no need to alter the motor in any way when using a tuned pipe like an Irwin or similar.
by winzracing » Sun Sep 02, 2007 11:20 am
Hey SteveM :D Thanks mate for that info...I was told that I had to get the timing changed as will damaged engine???..Going to leave it as it is..Also do you know what modifications are done on outboards to improve performance..eg cutting the piston on the intake side??? and exhaust on sleeve??? cheers
winzracing
by SteveM » Mon Sep 03, 2007 2:07 pm
I've never done any internal mods as I preferred reliability over outright power and I have no answers for you, sorry. I've seen a few 3.5cc motors with the pistons and sleeves machined for awesome power but never did find out what the guy did. :cry:
Users browsing this forum: No registered users and 58 guests
