K@B Marine 11cc
K@B Marine 11cc
Postby rosecrafts » Thu Aug 16, 2007 8:02 am
I have 11cc that is stamped 0003700. It runs great when water is not connected when bench testing, but when it stops ,water gets into the cylinder.It locks up. I clear it out and it will run. I pulled the cooling head and the button is slightly dirty but there is no shim. Should I replace the button or clean it and put in a shim? OR does it need a shim? If a shim is needed do I get one listed for the 5100 .67???? Is this motor the same as a 5100 .67? I need help Gary
rosecrafts
Users browsing this forum: No registered users and 21 guests
