3.5 Marine Outboard Shaft
Postby systemfailure » Sun Mar 25, 2007 8:11 pm
How do I lube the flex shaft without taking it out? Thanks
systemfailure
Postby SteveM » Mon Mar 26, 2007 3:49 am
The old trick is to remove the lower unit and separate the halves. Drill a small hole (1/16") at the upper flange directly inline with the center of the flex shaft.
The newer models now come with this mod as standard.
