KB 7.5 outboard
KB 7.5 outboard
Postby Peter T » Sat Mar 10, 2007 4:17 am
Please can you assit me I would like to know the part Number of the crankshaft that you use with Front housing 31-8722 The bearing size of the present crank I have is 15mm But on assembly with this housing when tightening the flywheel it pulls the crank forward and away from the
PTO Shaft pin location. I can see whats happening It looks like the crank is about 1/8" to short from the shoulder locateing the top bearing so when tigthening it pulls the crank forward.
appreciate your help
Peter
Peter T
Postby MECOA » Fri Mar 16, 2007 7:04 pm
as listed in the exploded view
http://www.mecoa.com/kb/87/870102-exp.pdf
17-8705
