K&B Crankshaft
K&B Crankshaft
Postby Carl Stevens » Fri Dec 29, 2006 7:54 am
I Have an older K&B engine. I use this motor to test newly built combat coreplast planes. The Crankshaft has been damaged and I need a new one.
Will a K&B Sportster series Crankshaft (.28= 17-5602) fit my older Crankcase?
Are they still avalible?
Could I fit a new remote carb and needle also?
Thank you for your help with this matter.
Carl Stevens
Postby MECOA » Sun Dec 31, 2006 6:51 pm
Did you look at our website www.mecoa.com ?
Here are the links
http://www.mecoa.com/kb/56/sportster.pdf
http://www.mecoa.com/kb/parts.htm
http://www.mecoa.com/kb/56/56-parts.htm
https://shop.mecoa.com/shopdisplayproducts.asp?id=156
I am not sure what "old crankcase" you are trying to fit it to. A .28 crank won't fit a .20
The prop stud is replaceable so you may not need a whole crankshaft.
Yes the new carb and remote needle will fit.
