7.5 Outboard
7.5 Outboard
Postby BillC » Sun Nov 12, 2006 5:48 pm
How do I remove the REAR BEARING from the FRONT HOUSING? And, do I require a remote needle valve assembly for a mixture disk carb?
THANX
BillC
Postby MECOA » Tue Nov 14, 2006 9:17 pm
You must heat the casting, kinda like...
http://www.mecoa.com/faq/cyl/remove.htm
Yes you probably need a remote needle if you have this carb..
http://www.mecoa.com/kb/carbs/Carb67.pdf
