6.5 & 4.9 Front Bearing Replacement Procedures + Sizes
Postby mojohn » Fri Nov 10, 2006 11:47 am
I have (6) 6.5's & 4.9's that I wish to replace the bearings in the front ends. I have both early and late versions & Both FIRE & RIRE. There seems to be several attachment methods for the Prop Driver. Please walk me through the correct procedure for disassembly & reassembly for these different types. Your Tech FAQ doesn't address this procedure and I don't want to ruin anything. Also, What are the correct bearing sizes/part numbers? Thanks, mojohn mojohn426@aol.com
2) 6.5 w/o ser.# / one has small hole apparently thru & set screw
/ other is plain adapter
1) 6.5 ser # 0979 plain adapter
1) 6.5 ser # 0461 plain adapter
1) 4.9 ser # B0000952 plain adapter
1) 7.5 I,B. ser # A0000337
mojohn
Users browsing this forum: No registered users and 24 guests
