Which ringed .61 crank do I choose?
Postby proptop7 » Sat Nov 04, 2006 4:21 pm
Hi...
I see 2 part #'s for the ringed .61's crankshaft.
17-6101 and 17-6103
I have a series 75 w/ the early , flatted prop driver. I'd like to stick with that style if possable.
However, I hear that that crank is no longer available? If so, which part # do I use to order, and what other parts do I need? I would assume the collet and drive washer, correct?
Tom
proptop7
Postby MECOA » Mon Nov 06, 2006 9:51 am
17-6103 has the 2 flats for the prop driver
Postby proptop7 » Mon Nov 06, 2006 1:49 pm
Thank you! 8) :)
proptop7
