by rpringle1028 » Fri Jun 09, 2006 2:08 pm
Thanks to MECOA for indicating that the bolts on the 21 engine are 4-40. I finally figured out that the bolts on the 15 are 3-48 (not a usually available size in Canadian hobby shops and hardware stores it seems).
Is there supposed to be a head shim/gasket and a backplate gasket on the 15 (Model 8301). The example I have does not have these, possibly indicating that the surfaces were machined and do not require these.
Rob
rpringle1028
by MECOA » Sun Jun 11, 2006 10:34 am
Which 15 are we talking about? The 15R or the Torpedo 15?
Both should have cover gaskets, head shims maybe, maybe not.
by rpringle1028 » Sun Jun 11, 2006 1:56 pm
This is the Series 72, Model 8301.
I asked about the backplate gasket since this is a rear intake engine and the gasket would change the clearances between the crankpin/crankshaft and the rotor. I have made a backplate gasket from 1/64" auto gasket paper and a head /shim from aluminium from a pop can.
Thanks.
rpringle1028
Users browsing this forum: No registered users and 99 guests
