by kesso2118 » Wed May 03, 2006 7:44 pm
I have an old 8906 Model Outboard and would like to upgrade the lower unit to allow me to run a tuned pipe.
If I order the Lower Unit Assembly Part No. 50-8903 does this come with everything e.g.
Lower Unit Halves
Water Tube
Screw Set
Prop Shaft Assembly (incl. Prop Nut & Prop Shock)
Flex Cable
Teflon Tube
I assume the Steering Arm Part No.56-8921 & Hinge Plate Part No. 56-8934 would also need to be ordered??
James
kesso2118
by MECOA » Fri May 05, 2006 7:55 am
The lower unit is complete with the parts you listed an even the hinge plate and pin are included. You would have to order the steering arm seperate.
by kesso2118 » Sat May 06, 2006 4:22 am
Thanks for the reply, I better get my order placed.
Regards,
James
kesso2118
