K&B 7.5 IB CARB QUESTION ?
Postby ksm73024 » Mon Apr 24, 2006 8:01 am
Hi there, I have a K&B 7.5 IB engine model no. 9181 with a big square carburettor on it that has the hi speed needle in one end & the idle mixture needle in the other end of the barrel.It also has a large velocity stack which is held in with two orings.Is this the right carb for this engine or should it have the carb with mixture disk & remote needle valve? Any help will be appreciated. Regards Craig.
ksm73024
Postby MECOA » Mon Apr 24, 2006 6:29 pm
this is the carb you are refering to
http://www.mecoa.com/faq/carb/kbsq/kbsq.htm
the one on the right, although made for the larger engines it was used on some 7.5's and should be okay for your engine.
