Torpedo-Rear Rotor .40 (RC) Back Plate
Postby nortonalday » Tue Mar 21, 2006 6:49 pm
I need a backplate assembly for this engine. The original is 8.9mm thick (interior-to-exterior thickness) & has the carburetor mount molded to the outside surface of the backplate. The piece I've received from you, part #8079/back cover is 16.3mm thick & a different configuration having the carburetor mount molded as an integral part of the assembly. Can you help?
nortonalday
Postby MECOA » Tue Mar 21, 2006 8:11 pm
I don't know what you have from the description. Please call or send pics.
