K&B .67 Marine
K&B .67 Marine
Postby rigged » Mon Jan 30, 2006 7:47 pm
hi.. was wondering if i will be safe using Odonnell 10% car nitro as long as i keep the needle fairly rich? I have it set at 3-3/4 turns from closed right now.
Thanks.
rigged
Postby MECOA » Wed Feb 01, 2006 10:00 am
No, running rich is not the answer.
You need 18% oil and may need to increase the compression ratio if you use that fuel. I don't know the oil content of his fuel.
Here is some reading
http://www.mecoa.com/faq/fuel/fuel.htm
http://www.mecoa.com/faq/breakin/breakin_abc.htm
http://www.mecoa.com/faq/compression/compression.htm
Postby rigged » Thu Feb 02, 2006 3:12 pm
thanks. From what ive been told, the RTR Odonnell car mix has 18% oil.
Right now the headgaskets are clearanced for 40%, but i have nowhere local that stocks nitro that high :(.
but anyway...if the Odonnell fuel truely has 18% oil, i should be safe running it in my boat?
rigged
Postby MECOA » Sat Feb 04, 2006 7:47 pm
You can raise the compression buy removing a shim. How do you know it is set for 40% nitro???
