K&B .40 (ringed)P.#booo2234 part's ?
Postby Guest » Sat Jan 28, 2006 12:30 am
well i just wanted to know if the parts for the other 40's listed are the same or up graded...,and also would like to know if they made a slide carb?
i've been trying to go to your home page mecoa.com and the site is down...or i just can't seem to figure out why i can't get in the home page..
this engine is still new never run...,but i don't have any paper work on this engine...it just came with the boat that i'm working on...also would like to know what . header/stinger pipe i should get for an in board for a K&B .40 ringed engine?(or) muffler pipe...
almost forgot! what is the HP/TQ. of this engine? it has a dome piston/cut chamber in the head button...and no head shim :cry: :cry: I know it needs one...well really not sure about that,so i'll leave that up to you to decide. :D
thanks for you time!!!
Guest
Postby MECOA » Sun Jan 29, 2006 8:20 pm
I don't know why you can't get into the site. They never came with a slide carb or head shim. See if you can link to this for the specs
http://www.mecoa.com/kb/marine/marine_outboard.htm
