by Sting » Tue Jan 10, 2006 4:19 pm
I am trying to remove PN# 188780 rear crank bearing and pn# 188446 PTO bearing from a K&B 7.5 OB Motor, there is no room to get a puller next to the back of the bearings.
How do you remove them?
Sting
by MECOA » Wed Jan 11, 2006 8:36 pm
You must use a puller and disassemble the bearing. Pull the bearing by the ball groove on the inner race.
by Sting » Thu Jan 12, 2006 8:46 am
Got a small chisel between the bearings and then was able to get a small gear puller to work.
Thanks!!
Sting
Users browsing this forum: No registered users and 207 guests
