Folks, hi, I am a novice working on building a Deep Vee 60 boat using a K&B Model No. 5100 Inboard Engine. I have 3 very basic, simple questions that I could not find in the forums or in the manual that came with the engine. Most of the boat has been build and the engine mounted but there are things on the engine I can't figure out. Any info would be greatly appreciated.
Questions:
1) there are 6 water fittings... I am not sure how they interconnect. Is there a diagram you can send me?
2) I have a tuned pipe hose coupler for the motor but not the tuned pipe. Can you make a recommendation on the tuned pipe I would need?
3) I have a K&B needle valve for the engine but I am unsure how it hooks up to the engine. I see the gas line connector on the carborator. I assume I mount the needle valve on the hull. On the needle valve, there are to places to hook up hoses. I assume the silver end goes to the gas tank and the copper one feeds to the carborator. Is that right?
Thanks in advance for answering these questions!
