Bent-Wire Needle Valve Assembly for Older K&B .61
Postby Brian » Tue Nov 15, 2005 6:45 pm
Hello,
I need the full needle-valve assembly (located on the carburetor) for an older K&B .61. I need the bent-wire needle valve, the spring nipple-nut, and the hex nut that screws onto the nipple-nut. I don't have any engine documentation, but I believe it's the model of .61 just prior to the remote needle-valve setup. Is the 87-5665 a full needle-valve assembly, or just part of it? If anything, what else will I need to order?
Brian
Brian
Postby MECOA » Wed Nov 16, 2005 7:20 pm
it the this carb pictured on the left here?
http://www.mecoa.com/faq/carb/kbsq/kbsq.htm
if so here is the exploded view
http://www.mecoa.com/kb/carbs/carb4061.pdf
