Engine cuts out at higher range
Postby Dave M » Sun Sep 04, 2005 5:53 pm
.40 K & B Marine engine. 70's model [4012], but till recently had not been run. Around an hour running time. Using 20% nitro mix. Cuts out at higher throttle. Carb has two set screws High and Low setting.
I've checked for Fuel leaks and does not appear to be the a problem. However when running I notice a few small air bubbles within the line to the carb? I've also pulled the carb apart and cleaned. Could this carb be defective? Is there better luck with the carb's with the needle valves separate from engine and carb?
Dave M
Postby MECOA » Tue Sep 06, 2005 7:35 pm
This is for an airplane but it also applies to boats
http://www.mecoa.com/faq/fuel/tank.htm
Hers's tuning info on the carb
http://www.mecoa.com/faq/carb/kbsq/kbsq.htm
and for a boat
http://www.mecoa.com/faq/carb/needle_marine.htm
doubtful carb is bad, maybe misadjusted.
Users browsing this forum: No registered users and 42 guests
