by cpmar123 » Wed Aug 24, 2005 6:04 pm
i have a used rear drum induction .45 . in order to get it on the tuned pipe i feel i have to lean it out too much. i know it is lean . it cut out soon after it is on the pipe.i don't feel there is any air leaks in the system. i'm using the recommended macs pipe,wildcat jet A 10% mccoy #9plug. any sugestions. pipe length ,fuel. i didn't find any suggested lengths for the pipe thanks for any reply Chris
cpmar123
by MECOA » Mon Aug 29, 2005 9:19 pm
It sounds like the pipe is too short or has too small a volume. Try adding a piece of tube about 1 inch between the pipe and header and see if it improves. If it does add another 1" and so on.
Also your fan may be too big.
maybe 25% and a K&B HP plug
Users browsing this forum: No registered users and 54 guests
