by Guest Doug » Sun Jun 19, 2005 7:40 pm
When I tighten the prop nut on my K&B 3.5, the prop drive washer actually scrapes the crankcase housing. If I loosten the nut, the motor will turn over. Do I need to replace the drive washer and cone or is there a shim to place on the back side of the cone? Thank you for your help.
Doug
Guest Doug
by MECOA » Tue Jun 21, 2005 8:44 am
You need to replace the collet (cone) and prop driver.
We do not have a shim.
