by Nickb » Mon Apr 18, 2005 3:44 pm
I removed the prop nut, shock washer and prop. Romoved the two small allen screws on bushing but won't come off??? I also have a little wobble in the prop shaft, when is it time to change it. Thanks
Nickb
by MECOA » Mon Apr 18, 2005 7:33 pm
You don't take apart the prop shaft. You can unscrew it from the lower unit (LEFT HAND THREAD) and then grease the flex shaft and prop shaft.
Users browsing this forum: No registered users and 103 guests
