Moving Needle Valve on Older Style K & B
Postby andernamen » Fri Apr 08, 2005 1:32 pm
I've got an old .40 K & B engine that I recently acquired off e-bay. It has never been run and appears to be 20-30 years old. The needle valve is directly on the carb and I'd like to move it back if possible. Can this be done? If so, what parts do I need and how do I do this. Also, is a gasket required between the engine and muffler? The box did not include one. Thanks, Jim
jereiter@juno.com
andernamen
Postby MECOA » Sat Apr 09, 2005 7:39 pm
No gasket between the muff and engine.
You would need to order the new style carb and remote needle.
look at
https://shop.mecoa.com/shopdisplayproducts.asp?id=140
part numbers
80-5902 and 9255
