New carb on old engine
Postby Mr. Slingshot » Sun Dec 05, 2004 1:23 pm
I have an old K&B 7.5 inboard marine engine with rear exhaust(bought in 1975). I would like to run an external needle valve assembly and a new style carb. The engine has been ported and has extensive flow work done to the engine. Is it possible to buy a new end plate to accept a new carb. Also what carb would be appropriate for a highly modified engine? I would appreciate any help I can get. Thanks!
Mr. Slingshot
Postby MECOA » Sat Dec 11, 2004 9:23 pm
What is the hole size you need it to fit into. .437 or .625?
Postby Mr. Slingshot » Sat Dec 18, 2004 5:21 pm
The neck size of the carb is .437
Mr. Slingshot
Postby MECOA » Sat Dec 18, 2004 6:43 pm
You want a 80-8903 or 80-8904
go to
and search by 80-89
all the carbs will come up
