Tubular Connecting Rod
Postby barry.sok » Fri Jun 13, 2008 11:39 am
I am currently rebuilding an older 7.5 outboard. Crank has .218 pin. The con rod I bought is the tubular style. How does it compate in strength to the flat machined style rod. It sure seems less substantial to me and weighs less too. Any thoughts.
barry.sok
Postby MECOA » Mon Jun 23, 2008 11:29 am
The tubular rod is made makes better RPM's than the flat rod. It is made from higher strength alloy than the flat rod. The cause of rod failue is mostly due to
http://www.mecoa.com/faq/conrod/broken/ ... conrod.htm
