top speed 2
top speed 2
Postby collins1172 » Tue Jan 31, 2006 6:31 pm
I am having difficulty planing my boat. I have a 3.5 K&B. The boat is a top speed 2. At first i thought the fexshaft was coming in and out. But i dont think that anymore because as it cuts in the water starts flowing out of the head and as the engine cuts out the the water quits flowing. I noticed on a hard turn the boat stays running longer and also at lower speeds. But as it just starts to come over idle it cuts out. I have balance the model at 2 and 1/2 ounces on the front. Im strting to think i may need more weight. The manual states that you need 1 and 1/2 ounces to balance it but also states that when using k&b you will need to extend the engine out 3/4 of an inch. Which could cause why i am using more weight. Does anyone know whats going on with my boat? Brad
_________________
My boat will not plane. I have a new 3.5 engine. It runs great however it seems to get air just as its about to plane. I have tried lowering the outboard no joy. Help please. Brad
collins1172
Postby MECOA » Wed Feb 01, 2006 10:06 am
You really need to contact the boat maker. We can only help with the engine here.
What size/make prop are you using?
planing issue
Postby collins1172 » Sat Feb 04, 2006 3:46 pm
prather 215
collins1172
Postby MECOA » Sat Feb 04, 2006 7:41 pm
You can try a Prather 220
But I would talk to the company that made the boat.
Postby winzracing » Sun Sep 02, 2007 2:47 am
Brad it sounds like the engine and trim need adjusting...Start off with a Neutruel trim and the prop shaft 1/8" above the bottom of the sponsons...Also put a x440 or x442 prop on there...Thats what i would check first before contacting the boat builders...What fuel you using??
winzracing
