9101 CONVERSION
9101 CONVERSION
Postby EKIMLL » Mon Aug 07, 2006 3:17 pm
HAVE A NEW K&B 9101,CAN IT BE CONVERTED TO A 9181 MARINE,
ENGINE AND NOT SPEND A LOT OF MONEY ?
EKIMLL
Postby MECOA » Wed Aug 16, 2006 7:37 am
To convert from a disk to drum valve you need to buy part number 21-8791, drum valve and back cover.
You also neet to either replace the crankcase with 10-8703
or
you have to mill (or Dremel) a passage for the intake of the drum valve. Fuel/air intake charge is directed upward toward the cylinder bore with the drum valve and a portion of the internal crankcase casting is in the way.
