Flex shaft breakage
Flex shaft breakage
Postby Zell » Mon Jan 03, 2005 3:53 am
I've only just got my 3.5ss outboard on my tunnel going on the water and as a shake down running i've borrowed a plastic prop but after about 1.5 hours running the flex shaft broke just near the prop shaft. Do you have any reasons for this as I thought this was a bit soon for this to happen.
Zell
Postby MECOA » Wed Jan 05, 2005 9:51 pm
We have a prop chart at
http://www.mecoa.com/faq/props/marineprops.htm
You may be using too large of a prop or did not keep the shaft greased. Please please read out website.
http://www.mecoa.com/faq/rust/marinerust.htm
