Vintage K&B .40 serial #H0000747
Postby oregonduck » Sun Oct 26, 2014 1:18 pm
I believe this engine is a model 8011. I was wondering about a marine conversion. I see Mecoa has a head button, and water jacket that will fit this model. Curious about flyweel and collet assembly. The prop hub has a pin in it. Also I see a thread in rc groups.com where someone has converted to marine. It seems he has kept the prop hub and just added a collet assembly without the use of the marine flywheel. It seems that the marine flywheel uses a tapered collet. What do I need to convert this engine to marine. Any thoughts appreciated.
Water Jacket: 11-4021 ×
Head Button: 11-4022 ×
Water Fitting: 54-8902 (2 required) ×
Glow Plug: K&B 1L #7311
3/16"Collet Assembly: 54-8791 ×
3/16"Collet: 54-8792 ×
Large flywheel (tapered): 20-4021 ×
Flywheel collet (tapered): 19-6101
oregonduck
Re: Vintage K&B .40 serial #H0000747
Postby oregonduck » Sat Dec 27, 2014 5:21 pm
So I came across someone selling some .40 k&b parts. I have got just about everything I need for this conversion. Question on the flywheel. The flywheel is off a marine 4012, so it has the tapered end on it. My 8011 has the small flywheel with pin installed through flywheel. I know that the 4012 has a bigger front bearing than the 8011, so will the flywheel collet (tapered bushing), with the larger flywheel work on my 8011? Thanks for any help
oregonduck
Users browsing this forum: No registered users and 31 guests
