3.5cc O/B Marine
3.5cc O/B Marine
Postby viking61 » Sun May 23, 2010 1:06 am
I have a new one but as I look at it it doesn't have a shock block used to put tension on the prop nut. My older is different prop nut also. RJL makes the K&B and Tower sells the OS outboad. Tower is beginning to suck as they don't carry alot of items as conflict of interests. No Sig model kits/ No K&B engines. I want to get my Marine engines on same sheet. The new engine came to me no papers/ used one has real old speck sheet. Also what do they use tool wise for starting cone on top of engine.?? New project for me.
Cheers,Dan :arrow: :arrow: :idea: :?: :?:
viking61
Postby chiefss » Sun May 23, 2010 2:24 pm
Mecoa is the only seller of K&B as they now own the K&B.
The big Tower catalog shows several SIG kits.
Nothing to do with "conflict of interest".
3.5cc O/B Marine
Postby viking61 » Mon May 31, 2010 7:15 pm
OK the main difference beteen my two engines is the prop nuts are different. The newer one has smaller lenght and looks like some type spacer called Prop Shock#56-8731. Also newer engine has different steering arm #56- 9821. I will try Randy to put an order in for these.
I was at a local boat race here in Tucson and all boats were gassers. Not one nitro. Looks like electric and gassers are coming on real strong.
Dan
viking61
Users browsing this forum: No registered users and 30 guests
