outboard props.3 blade or 2 ????
Postby jus1moore » Sun Mar 14, 2010 9:00 am
Ihave a k&b 7.5 & a 3.5 outboard on tunnel hulls . ive always ran the recomended 2 blade prop on the 7.5 havent ran the 3.5 yet. would the 3 blade give me better proformance on either of these???? the 7.5 flys pretty good now but i like to go a little bit faster ( who dont) no tuned pipes yet. everything is stock. bin thinkin about a hotter carb also on both. any input would be great. thanks
jus1moore
Postby SteveM » Sun Mar 14, 2010 9:28 am
3-blade props give a bit more rear lift compared to a 2-blade. I've run a X437/3 on the K&B 3.5cc but tended to use the X440/2 or even the X442/2 cut down to the same diameter as the X440. The Prather 215 wasn't too bad as well. The X440/3 was a bit too much blade area for my motors. I was never happy with a 3 blade on my 7.5 outboards.
Postby HappyOne » Wed May 05, 2010 6:56 pm
Like Steve said, the two blade props seem to work the best. I have used a three blade prop, depending on water conditions, to get the boat up faster coming out of the turns. You should probably have both on hand at the pond.
HappyOne
Users browsing this forum: No registered users and 14 guests
