HB .25 Question
HB .25 Question
Postby kennyk27 » Fri Jun 04, 2010 8:56 am
I have an HB .25 with a Perry carb on .. I suspect carb problems.. can I replace a Perry carb with another style to run the HB .25.. do I have to buy another Perry? any advice is appreciated.
kennyk27
Perry carb.
Postby max hansen » Sat Jun 05, 2010 9:14 am
Don't replace it as it is one of the best ones made. About the only things that can go wrong with one is the two "O" rings get hard ( won't idle) & run erratic (dirt in carb in area between the two "O" rings ). These should always be run with a filter . Last is improper adjustment ,follow directions. I have never seen one wore out but a lot of broken ones but they didn't break the intake like aluminum ones do. Give it a try. Max H. :)
Users browsing this forum: Google [Bot] and 13 guests
