i need your expert advice to understand how to take a part an old O.S. Max 10. I have this motor on an old Kyosho WildCat Buggy, it was blocked by old fuel but i've been able to free it up, it still turn a little "sticky" and now i'm stripping it down to be able to clean and restore it.
It's the first time that i work on one of these engines and my problem is that i'm not able to take off the piston..., can someone tell me the technique? Have i to remove the sleeve? It has a sleeve...? How can i do it? It seems blocked like was the piston. Have i to use heat?
There is someone that have an exploded view of this motor?
Here below the picture of the motor how it is now.
Thanks in advance for your help.
Bye
JC[/img]
